Shows the bender ready to bend a tab. The bender's parts are labelled.
Portable Network Graphics (PNG) -
924.61 kB -
04/07/2020 at 20:46
Preview
The shape of the hinge prevents the workpiece from lying flat. Because of that, and to increase rigidity, a top plate should be added.
463.30 kB -
04/07/2020 at 20:46
Preview
Shows adjacent bends offset so a rivet tab can slide in behind a side.
312.98 kB -
04/07/2020 at 20:46
Preview
A close up of a piece of aluminum being bent. Note that it bends closely around the front profile of the finger.
JPEG Image -
121.77 kB -
04/07/2020 at 20:46
Preview
A close up of a piece of stainless steel being bent. Because of its stiffness, it makes an air bend rather than conforming to the shape of the finger.
JPEG Image -
113.47 kB -
04/07/2020 at 20:46
Preview
Shows a nut and bolt used for pulling the hinge leaves together to make a bend. This means that the workpiece can be bent completely around the finger to form a tube.
17.86 kB -
04/07/2020 at 20:46
Preview
This shows how machine screws hold everything together and align the bends.
28.87 kB -
04/07/2020 at 20:46
Preview
