The STM8S103F3 "blue pill" breakout board. USB power connector (no data connection... bummer) provides 5V operation. The swim connector can reprogram it and also power it via 3.3V if you run a ground wire from the swim ground to Vss pin 7. My swim ground header pin does not seem to be connected to anything else on the board.
