Here's the Arduino code!
// LED color interpreter // Made by Thomas Burns // www.thomasburns.net // last revised: 04/12/2020 #include <adafruit_neopixel.h> #include <wire.h> #include <liquidcrystal_i2c.h> int red, green, blue = 0; // I2C pins declaration LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // IMPORTANT: Set pixel COUNT, PIN and TYPE #define PIN 2 #define NUMPIXELS 10 // Initialize the neopixel strip Adafruit_NeoPixel strip(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800); void setup() { // Set the pins connected to the potentiometer as inputs pinMode(A0, INPUT); pinMode(A2, INPUT); pinMode(A3, INPUT); // LCD lcd.begin(16, 2); lcd.backlight(); delay(1000); // AV test strip.begin(); strip.show(); // Initialize all pixels to 'off' // magenta chase for (int i=0; i<=9; i++) { strip.setPixelColor(i, 56, 11, 69); strip.show(); delay(50); } // yellow chase for (int i=0; i<=9; i++) { strip.setPixelColor(i, 85, 48, 12); strip.show(); delay(50); } // cyan chase for (int i=0; i<=9; i++) { strip.setPixelColor(i, 56, 100, 100); strip.show(); delay(50); } // clear LEDs for (int i=0; i<=9; i++) { strip.setPixelColor(i, 0, 0, 0); strip.show(); delay(50); } delay(200); lcd.setCursor(0,0); lcd.print("Good"); delay(100); lcd.setCursor(0,0); lcd.print("Good evening,"); delay(500); lcd.setCursor(0,1); lcd.print("Thomas."); delay(2000); lcd.clear(); delay(500); // print static text in setup to prevent flicker lcd.setCursor(0, 0); lcd.print("Red 0"); lcd.setCursor(8, 0); lcd.print("Grn 0"); lcd.setCursor(0, 1); lcd.print("Blue 0"); } void loop() { // Read and store the potentiometer values // We are scaling them from a 10bit scale to an 8 bit scale red = analogRead(A0) >> 2; // 10 to 8 = shift two bits green = analogRead(A2) >> 2; blue = analogRead(A3) >> 2; // set colors of all the eight neopixles for (int pixel = 0; pixel < 16; pixel++) { strip.setPixelColor(pixel, red, green, blue); } strip.show();//Update the strip with new color values delay(50); // LCD code lcd.setCursor(4, 0); // move cursor just behind the static word "RED " lcd.print(" "); // 3 spaces to clear previous value lcd.setCursor(4, 0); // back to pos 5 again lcd.print(red); // print value lcd.setCursor(13, 0); lcd.print(" "); lcd.setCursor(12, 0); lcd.print(green); lcd.setCursor(5, 1); lcd.print(" "); lcd.setCursor(5, 1); lcd.print(blue); }
Can you please share the BOM and schematic files? Thanks!
