Last I left off, I was trying every incantation of tcpdump I could muster with little success. It was obvious the projector was self assigning an address and simply not broadcasting *anything* to the network. I tried some broad range ping sweeps but between fighting routing tables and the likelihood an embedded device like this would ignore pings (it didn't) I didn't put a lot of effort into this. Instead I sank to the last resort of any hacker worth their weight in flux and I... contacted the manufacturer.
And it worked! A couple of nice folks at Visitech got back to me with some basic questions and gave me a dropbox full of documents!
As suspected the device self assigns an address on reset, 192.168.0.10, how'd my ping sweet not hit that?!? I blame the routing tables.
So the auction closed and I ended up getting the complete unit for $US50. I have been unable to determine what a unit like this went for new, but I can image it being much, much higher than this.
Hardware Rundown
This lot (there were 4 total) came with, PSU, the main projector unit and an optical stage. I'm unsure what the optics are setup for (shrink, enlarge) but one of the other lots included a frame, with an acrylic bed about 10cm above the lens.
Unit Body
The main body includes several ports, PSU, two optical sync (IN/OUT), and electrical sync, 6 GPIO pins, Ethernet, a reset button and ethernet reset button. PSU was helpfully labeled and allowed me to confirm the include supply was correct and wired correctly. With that I was able to power it up to find the fan grill hit the blades and made a horrendous noise. But with that fixed, I was able to see if I could get it on the network.
Ethernet
The best info I can find for this is the 'datasheet' for a similar (might be the same?) model called the LE4960H DIS. The DIS part of this indicates the projection optics and the controller are separate, presumably allowing the optics to be mounted in more confined places. The H part is still an unknown. The important part though is the fact this datasheet says the control is web based, and the host controller simply needs a browser. And hey, I've got one of those.
The Problem
So this browser based control seems really handy, problem is, so far nothing I've tried will get this thing on my network. I doesn't seem to ask for an IP, isolating it on a switch with my desktop I cannot see anything going out with tcpdump but the ethernet LEDs on the device are lighting like they're trying to do something. I also tried hooking it directly to my desktop but only one LED lit up, I'm guessing this is a patch/cross over cable thing issue? Or maybe something with 1000Base-T ethernet that I don't understand?
Any suggestions would be handy, this is pretty much where I'm at.
Do you use or did you need to configure the external trigger signal: optical or electrical; positive edge or negative edge. Luxbeam 4600>system setup>external trigger signal. What settings did you use? How does that setting affect your image?
Not that I recall, I believe I just uploaded a picture and it worked. I'll be trying to get this set back up in the near future, just need to clear a space it can live permanently.
You said you where able to get documentation from Visitech for this chipset. The laser I use at work has the same chipset and Visitech has not sent me any documentation per my request to them for it. Please upload those to "files" so I can DL. Of particular interest is using the integrated software for troubleshooting.
