First experimental boot on ATSAMD51
04/27/2020 at 20:59 • 4 commentsFirst experimental boot on ATSAMD51 M4 core 120 MHz, 512 KB flash, 192 KB RAM + 8MB SPI FLASH . Theoretically can run #circuitpython This board is originally designed as game console for https://arcade.makecode.com/
- I am only removed RTC support :)
- Expecting troubles with sharing SPI between LORA and display
Assembled and working ;)
04/17/2020 at 22:45 • 0 comments![]()
New boards .. Armachat - FUSION
04/17/2020 at 20:41 • 0 commentsFUSION:
Take advantages from currently both version:
- POCKET: Samd21E18 (easy to solder), Keyboard layout 6x5 matrix
- DESKTOP: 18650 battery, bigger buttons easier to solder and better for ussage
- 76mm x 71mm is best compromise for comfortable keyboard, display and battery
- PCB front panel .... manufacturing on PCB factory make super cool look and no laser or other tools are required
Something about front plate ...
04/13/2020 at 17:36 • 0 commentsIt is made from special 2 layer laserable plastic
https://www.innograv.com/en/engraving-material/laser-engravable/laserplus/1692/laserplus
This plastic is amazing because I can cut engrave with my 2W diode laser !!!
- Something about my laser machine https://hackaday.io/project/164820-pajamas-micro-laser-engraver
Plastic 1.6mm thick
3mm plastic is also able to cut, I am using it to make CNC parts :)
swap 2 colors
Project box ...
bobricius
