aquametric-electron3.ino
Latest Sensor Firmware
ino -
7.50 kB -
10/05/2020 at 02:51
Download
Aquametric_2020-10-04_22-49-33.json
EasyEDA Schematic File
JavaScript Object Notation (JSON) -
31.93 kB -
10/05/2020 at 02:50
Download
SensorBody.stl
(Old Sensor Version) The batteries and microcontroller live here. The wires that run outside of the sensor are to be potted with epoxy.
Standard Tesselated Geometry -
619.81 kB -
04/10/2020 at 22:57
Download
Lid.stl
(Old Sensor Version) The ultrasonic sensor is epoxied into the hole.
180.65 kB -
04/10/2020 at 22:57
Download
AntennaHousing.stl
(Old Sensor Version) This is epoxied to the main sensor body. The pcb antenna is attached on the inside.
194.52 kB -
04/10/2020 at 22:59
Download
PoleCollet.stl
(Old Sensor Version) This holds the device on the aluminium extrusion.
47.45 kB -
04/10/2020 at 22:59
Download
