Debug Header (SWD)
04/13/2020 at 21:39 • 0 comments5-pin header on the main board, goes right to the main STM32F429ZI processor... utilizing the Serial-Wire Debug interface from the chip.
** Note: ** developers enabled the 'read protection', so can't easily dump the main flash of the chip to capture the main firmware, not sure how this firmware in the cpu's 2MB flash releates to the FW update files.. but would have been nice to try and understand the correlation.
Hall Effect Sensor
04/13/2020 at 21:36 • 0 commentshall effect sensor, only number on it was 'MDH4YE', but doesn't seem to reference to anything.. maybe it's just a production number and not a true part number..
LCD Interface Ribbon Cables
04/12/2020 at 20:39 • 0 comments(parallell RGB interface is left cable, Touch Interface Int. Controller is on right)
wifi module
04/12/2020 at 14:53 • 0 comments -
8MB Flash
04/12/2020 at 14:30 • 0 comments -
microsd socket
04/12/2020 at 14:27 • 0 comments -
bluetooth module
04/12/2020 at 13:34 • 0 comments -
bluetooth pcb
04/12/2020 at 13:33 • 0 comments -
04/12/2020 at 13:31 • 0 comments...
More Photos...
04/12/2020 at 13:28 • 0 comments
