S260320-R241023_IOS_V20-MBC.zip
The sketch for the IOS (with the needed libraries). Unzip into a folder and open the .ino file (with Arduino IDE). IOS must be uploaded into the Atmega32A flash. Added MSDOS support. See the Changelog in the .ino file. The Serial port default speed is 115200 bps (8N1).
Zip Archive -
42.94 kB -
11/04/2023 at 12:35
Download
S260320-R241023.ino.with_bootloader_atmega32_16000000L.hex
The sketch for the IOS in executable format (.HEX) with the bootloader. This executable file is intended for use with a programmer as the Atmel Ice or AVRISPmkII or others (Fuse bits: High Byte 0xD6, Low Byte 0xAF, Lock Byte 0xCF)
x-hex -
62.91 kB -
11/04/2023 at 12:36
Download
SD-S260320-R241023-v1.zip
The content of the microSD for IOS S260320-R241023. Added the SPP Adapter board support for CP/M 2.2 and CP/M-86. See ChangeLog.txt inside the SD image.
Zip Archive -
5.07 MB -
11/04/2023 at 12:35
Download
A250220 - SCH.pdf
Schematic.
Adobe Portable Document Format -
221.90 kB -
04/21/2020 at 11:27
Preview
A250220 - Gerber.zip
PCB gerber files.
Zip Archive -
481.69 kB -
04/21/2020 at 16:10
Download
A250220 - Assembly guide.zip
PCB Assembly guide.
x-zip-compressed -
101.52 kB -
04/21/2020 at 11:27
Download
A250220 - BOM v3.ods
BOM file.
spreadsheet -
14.97 kB -
04/10/2021 at 08:56
Download
CPM-86 Personal Basic 1.1 Tutorial.pdf
Tutorial and manual for DRI Personal Basic v1.1 for CP/M-86. Please read it before to start using Personal Basic for CP/M-86.
2.79 MB -
06/04/2020 at 09:45
Preview
uPD70108H (V20HL).pdf
V20HL (uPD70108H) Datasheet.
2.14 MB -
04/18/2020 at 09:10
Preview
80C88 Datasheet.pdf
80C88 Datasheet.
1.72 MB -
04/23/2020 at 08:28
Preview
