1Print 3d parts
You will need:
- 4x side stl
And depending on your driver choice:
- 1x apc or lpc stl
- 2x wago_apc or wago_lpc stl
2Mount driver
Screw driver of choice to their base, using M2/M2.5 screws
3Add side pieces
Screw side pieces to driver base, use m3 screws and nuts, wait to tighten.
4Add led bars
Screw led bars to the side pieces, without tighten to much.
5tighten everithing up!
Once all pieces are in places, make sure everything is firmly tighten
6Screw wago connector base
Screw the wago connectors and put them in place
7Wire driver and led bars
Connect it as in scheme, add a bit of tin at the end of the cables that are going to the led bars, also you can add some male connector or you can add liquid electric tape over the connector to isolate them.
8Add AC cord
Connect it in a safe way, using other wago connector for example
9Plug and Enjoy!
Any photos of your build, veggies you raised with this or or remixes are very welcome :)
Niko
