Hackaday.io Hackaday.io
Sign up Log in
DIY Food Dispenser
I built a food dispenser that serves me the exact amount of 4 different ingredients (Oat, Protein Powder, Chia and Flax seeds).
elite-wormElite Worm
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
8 comments
15 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 8
View Gallery
471
8
15
25
Team (1)
  • elite-wormElite Worm
Join this project's team
completed project
MISC
3d printing arduino display prusa pcb electronics design
This project was created on 04/15/2020 and last updated 6 years ago.
Description
I designed and built a food dispenser that serves me the exact amount of 4 different ingredients (Oat, Protein Powder, Chia and Flax seeds). I used an ATmega328p as the microcontroller and a Nextion touch display. It utilizes 4 micro servo to allow more or less amount of ingredient come out of the containers and a linear type of movement (shake) to avoid clogs.
Details
Log In/Sign up to comment
Sign up with Github
OR
Sarah hossam wrote 04/23/2020 at 09:26 • point
very interesting project. Well done
Elite Worm wrote 05/17/2020 at 10:54 • point
Thank you Sarah!
FLX wrote 04/19/2020 at 05:45 • point
Well done. This is an original method.
I think it only misses a way to adapt regular bottles / food safe containers
Are these shakers working as good as a screw pump ?
Elite Worm wrote 05/17/2020 at 10:53 • point
I haven't had the opportunity to compare it to a screw pump but I'm pretty happy with how it performs.
stefan.schnitzer wrote 04/17/2020 at 10:22 • point
Cool project! How do you measure the dispensed amount of each ingredient?
Elite Worm wrote 05/17/2020 at 10:52 • point
By measuring the weight with the scale.
Dan Maloney wrote 04/16/2020 at 16:24 • point
Impressively complex! I wonder if you fill the legs with some kind of heavy ballast, like plaster - that might help the excess vibration problem. Assuming they're hollow, of course.
Yes! That would be an easy way to get rid of the vibrations... They are almost hollow (20% infill).
Making an 16x8 matrix array of IN-3 Nixie bulbs.
Project Owner Contributor
Nixie IN-3 Matrix
robin-sterlingrobin sterling
In 2011, I worked on a prototype head mounted display using two smartphones as display panels for left and right eyes. It used LEEP lenses.
A Smartphone-Based Head Mounted Display
dkrumdkrum
3D printed HUD display. Used in car to display maps, navigation, speed, time etc.
HUD display for cars
thiagesh-dthiagesh D
2021 Hackaday Prize
This display does an impossible task ! it keeps the image ALWAYS facing the spectator whatever the angle of observation !
Omnidirection display
salahSalah
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY Food Dispenser", please tell us the reason.
Send message
Remove Member
