Sometime, somewhere, someone
05/24/2020 at 20:40 • 0 comments4/23/2020
Let me explain. I wondered if it was possible to use the #TRS-80 (#PigFX font 1) graphic characters to build the chess pieces. So I wrote some Z-80 assembly code to print them out (the 'M' is just a separator) through the SCM I/O calls. I printed both white foreground on a black background, and black foreground on a white background:
Then I mapped out the graphic character blocks in a spreadsheet:
I realized they were much like the Jupiter III Wavemate 2x3 graphics. In generating a translation table I discovered the font matched the Sargon black on white chess piece tables exactly. The book, I found, does call them graphic characters. Sometime, somewhere, someone defined these graphic characters and they became an early standard. Good thing, because there is still a problem here...
Font Graphics
05/24/2020 at 20:04 • 0 comments4/23/2020
OMG! It looks like the PiGX font 1 is going to make recreating the original #Sargon UI way easier then I expected.
The Problem Was
05/24/2020 at 19:57 • 0 comments4/22/2020
The problem is you cannot upload HEX files thru the #PiGFX S/W running on the #RPi to the Small Computer Monitor running on the #RC2014 mini. This is unfortunate since the bulk of the changes I need to make to #Sargon is the graphic UI.
But it turns out that if I leave the #RC2014 mini configured to use the #FTDI serial port, the output also goes through PiGFX to the HDMI monitor. This means I can upload HEX files using #Putty and still see the graphics on the monitor.
And that's fine! For development I don't care if the keyboard is attached to Putty or PiGFX. Except for the UK/US Keyboard layout difference. The UK keyboard could force me into branching PiGFX eventually. But for Sargon it may not matter.
Problem solved!
The Small Computer Monitor
05/24/2020 at 19:42 • 0 comments4/17/2020
As soon as I discovered the ROM on my #RC2014 Mini is OTP, I ordered a UV erasable and began exploring ways to debug #Sargon #chess in RAM. It turns out there are two boot-able images available on the RC2014 Mini, Basic and The Small Computer Monitor (SCM). SCM allows uploading HEX files, so I've set the the RC2014 jumpers to boot it.
TDL Macro Assembler
05/24/2020 at 19:25 • 0 comments -
PiGFX
05/24/2020 at 19:07 • 0 comments4/11/2020
I got the PiGFX ANSI terminal running on the RPi Zero plugged into my #RC2014 Mini. I've run across two versions; pictured is Version 1.1.2 which has better resolution characters. I found I needed to ignore the PigFX instructions to limit the partition size of the Micro SDHC card. 16 or 32 gig works fine. I also realized a RC2014 reset is required, after PiGFX boots, so that PiGFX will see UART data. Does anyone know how to switch PiGFX from a UK to US Keyboard?
Too Easy
05/24/2020 at 19:03 • 0 comments4/11/2020
Too easy. Nicely done @ZxSpectROM!
I'm going to use the second 8K page of the ROM for #Sargon #Chess. I want to adhere as close as possible to Dan and Kathe Spracklen original design. See their book here:https://web.archive.org/web/20070614114334/http://madscientistroom.org/chm/Sargon.html
Too Easy
Smoke Test
05/24/2020 at 15:21 • 0 comments4/11/2020
Well that was a lot easier than the first computer I wire wrapped in the late '70s. This is a fine kit with good instructions. I'm going to test it with this USB COM adapter first. Notice I added C3 that wasn't included in the kit. Let's find out if it comes with smoke !
Build
05/23/2020 at 04:33 • 0 comments4/10/2020
Working on a Sargon chess computer. This will have a PI Zero plugged into it that will serve as graphics terminal.
