Pergola is a Lattice ECP5 FPGA development board.
- 5 PMOD connectors
- 2x 64Mbit SPIRAM
- 8 LEDs- 1 user button
- i.MX RT1011 MCU for configuration and data transfer with a HiSpeed USB Host.
Status as of 2020-05-01:
Project is still alive.
Working on firmware.
Bootloader using TinyUF2 works.
Planning a new revision that fixes the issues found in RevA 0.1.
Will improve diff-pair routing, so expect pins to change.
RevA 0.1:
Works, but has a few issues. Issues are bodgeable.
10 units have been produced and distributed to early adopters.
Konrad Beckmann
Parker
arturo182
Jon Thomasson
Where have you had your boards made that deal with the tight constraints necessary to fully escape the ECP5?
