Quick demo board made with Eagle and working with GCC G++ OpenCM3 Makefile FreeRTOS CAN
Revision 10x10 v2 fixed. It works.
Updated FreeRTOS configuration.
I fixed some basic errors on the board:
I added a new layout 10cm x 8cm and sent it to a cheap Chinese PCB lab. I will upload some photos when receive it.
Added CH340G to UART1 for firmware burning through STM32F bootloader.
View all 5 project logs
Install ARM-GCC, makefile and stm32flash
sudo apt-get install gcc-arm-none-eabi makefile stm32flash git
Clone repo:
git clone https://github.com/yangosoft/stm32f103c8-board.git
Compile
cd stm32f103c8-board/code/freertos_stm32f103 make
View all 4 instructions
I have also make this but facing issue kindle check it out
https://gta-6.pro/gta-6-trailer/
BTW I got the hardware side done here. :) https://hackaday.io/project/6607-stm32f103-canadian-maid-breakout-board
¡That is a better board! And it's better routed.
Ethan Durrant
Stefan Wagner
WingTechCorner
arturo182
Yes, delete it Cancel
You are about to report the project "STM32f103c8 board", please tell us the reason.
