10x8 v2
11/19/2015 at 07:52 • 0 commentsI fixed some basic errors on the board:
- Capacitors more close to the STM32
- VBAT connected
- VSSA connected to ground
- VDDA connected to VCC
Layout 10x8
09/16/2015 at 06:41 • 0 commentsI added a new layout 10cm x 8cm and sent it to a cheap Chinese PCB lab. I will upload some photos when receive it.
Revision 7. CAN USB changed
09/10/2015 at 12:15 • 0 comments- Removed UART pins
- UART1 RX and TX are routed only in CH340G
- CAN changed to alternative pins in order to avoid USB sharing
- Added again ground planes
v5 layout
09/07/2015 at 15:37 • 0 comments- Revision 5 with better layout, pullup in USB+ and a CH340G.
- Still missing a better solution with shared lines in CAN and programming USB.
- Ground planes removed.
CH340G
07/30/2015 at 15:08 • 0 commentsAdded CH340G to UART1 for firmware burning through STM32F bootloader.
yangosoft
