STM32f103c8 board
Quick demo board made with Eagle and working with GCC G++ OpenCM3 Makefile FreeRTOS CAN
This project runs FreeRTOS 8.2.1 with OpenCM3 through STM32F103C8, a cheap ARM 32bits Cortex M3, in a custom board designed with Eagle 7.
Revision 10x10 v2 fixed. It works.
Updated FreeRTOS configuration.
  • 1 × stm32f103c8 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × USB to Serie
  • 10x8 v2
    yangosoft11/19/2015 at 07:52 0 comments
    I fixed some basic errors on the board:
    • Capacitors more close to the STM32
    • VBAT connected
    • VSSA connected to ground
    • VDDA connected to VCC
  • Layout 10x8
    yangosoft09/16/2015 at 06:41 0 comments
    I added a new layout 10cm x 8cm and sent it to a cheap Chinese PCB lab. I will upload some photos when receive it.
  • Revision 7. CAN USB changed
    yangosoft09/10/2015 at 12:15 0 comments
    • Removed UART pins
    • UART1 RX and TX are routed only in CH340G
    • CAN changed to alternative pins in order to avoid USB sharing
    • Added again ground planes
  • v5 layout
    yangosoft09/07/2015 at 15:37 0 comments
    • Revision 5 with better layout, pullup in USB+ and a CH340G.
    • Still missing a better solution with shared lines in CAN and programming USB.
    • Ground planes removed.
  • CH340G
    yangosoft07/30/2015 at 15:08 0 comments
    Added CH340G to UART1 for firmware burning through STM32F bootloader.
View all 5 project logs
  • 1
    Step 1
    Install ARM-GCC, makefile and stm32flash
    sudo apt-get install gcc-arm-none-eabi makefile stm32flash git
  • 2
    Step 2
    Clone repo:
    git clone https://github.com/yangosoft/stm32f103c8-board.git
  • 3
    Step 3
    Compile
    cd stm32f103c8-board/code/freertos_stm32f103
    make
View all 4 instructions
Rich text editor
vapesforyou7 wrote 11/14/2023 at 17:11 point
I have also make this but facing issue kindle check it out
https://gta-6.pro/gta-6-trailer/
K.C. Lee wrote 07/29/2015 at 15:14 point
BTW I got the hardware side done here.  :)  https://hackaday.io/project/6607-stm32f103-canadian-maid-breakout-board
yangosoft wrote 07/30/2015 at 07:50 point
¡That is a better board! And it's better routed.
