The short video shows the system in response to motion detection.
Camera Server with supporting 5 POE cameras, USB storage, internal power supplies and light indication of motion detection.
RJ45 KEYSTONE PLATE POE.stlStandard Tesselated Geometry - 262.97 kB - 05/03/2020 at 22:31 |
ATX PSU BACK PLATE.stlStandard Tesselated Geometry - 113.56 kB - 05/03/2020 at 22:23 |
Working on finishing up some of the front panel details. Attached 8x8 RGB panel, connected the switch and a little bead board so the front panel can easily be removed by unplugging cables.
There is a DS18B20 sensor that is not currently working with node-red, will be shortly.
The lead screws pull and push holders for the usb hard drives, supports 2 but only 1 is currently being used. Using a screw driver you can push in to disengage the little gears, then turn to clamp the drive into place.
What are the lead screws doing?
