About Project
PIR Sensor basically is an electronic sensor that regulates infrared (IR) light radiating from objects in its field of view.
These sensors also allow you to sense motion and is mostly utilized to discover whether a human has moved in its range.
You will require 5 jumper wires to combine everything, all of these wires should have male-female connectors.
You can set the frequency to 3000 Hz because as most alarms use this frequency. The PIR sensor is basically a movement sensor so whenever it recognizes movements, it sets OUT to HIGH, the user can also control the time of this HIGH state and the sensitivity of your sensor with the 2 potentiometers.
This project produces beep sounds when any movements are recognized. We can easily modify the time of the beep by changing the delay time at the end of for loop.
hIOTron
RealCorebb
eGuidezhan
electronicsworkshops
