We have friction fit!
05/21/2020 at 13:52 • 0 commentsOkay, printed version 4 yesterday with 14mm x 14mm switch holes. The switches snap in satisfyingly, but unseat a bit when pulling keycaps. I might hot glue them in place. Superglue would be better, but more likely to seep in and ruin the switches.
Now I have plastic knuckles for both hands
05/13/2020 at 15:27 • 0 commentsFor version 2, I pulled the thumb switch closer, made the switch holes 15mm, and minkowski'd out the sharp corners. The switches don't fall through now, but there is a gap that's too big to fix with hot glue.
Already wasted some plastic on this thing
05/12/2020 at 14:06 • 0 commentsPrinted this last night, and the switches fell right through. :(
Also, I think I will adjust the thumb area, because my thumb isn't long enough to really reach it now.
