This week I setup project management Kanban board on GitHub:
https://github.com/01binary/drummingrobot/projects/1
Last sprint I had a lot of trouble finding shock absorbers for the arms and the torso. Today I finally found RC car drive links that I can use for the arms instead of shocks, and small motorcycle shocks that I can use for the torso.
Drive links: https://www.amazon.com/Integy-Hop-ups-C27173SILVER-Machined-Suspension/dp/B076F3YCY9
Shocks: https://www.ebay.com/i/273547931664
Another task that I had trouble with for a while is sourcing a DC motor responsible for turning the torso. I looked at ClearPath motors but they are not powerful enough. Since I would like to run the robot on batteries, AC motors are not a good option. It's likely that I will need planetary gear rotating platform or something else that will let me use multiple weaker DC motors to turn the torso.
The servos responsible for rotating arms are over $1000 each (Dynamixel Pro) so I would rather not get a $4000 motor for the torso in addition to that - too wasteful on the resources since torso motion is not critical to this design.
