The latest archive AS20241228.tgz adds a first version of a stack-based arena allocator, using the same mark-new-release ideas as in Turbo Pascal.
This is a sort of reboot of the ideas of #A stack.. It's still a dumb mark-new-release allocator but it is multithread-compatible, you can locate the buffer anywhere you like in data memory.
