Hackaday.io Hackaday.io
Sign up Log in
E-skateboard with torque vector steering
If you had four of these skateboards you could haul a couch.
adam-langeAdam Lange
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.9k views
7 comments
10 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 7
View Gallery
1.9k
7
10
8
Team (1)
  • adam-langeAdam Lange
Join this project's team
ongoing project
This project was created on 05/15/2020 and last updated 6 years ago.
Description
Electric skateboards don't have much cargo capacity. Self driving swarms of skateboards could help to increase skateboard cargo capacity.
Project Logs
Collapse
  • The hardware
    Adam Lange • 05/15/2020 at 00:41 • 0 comments
    This part is a bicycle headset with a hall effect encoder.  It allows the front axle of the skateboard to freely pivot and senses the axle angle so that the controller can hold the desired steering angle by sending torque commands to the left and right wheels.
  • Skating with torque vector steering
    Adam Lange • 05/15/2020 at 00:27 • 0 comments
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
jemimelan wrote 10/11/2020 at 11:07 • point
This is looking so great. I'm also working on the same project for my automatic skate running. You can read here the review of skateboard https://skateboardslife.com
Kyle Brinkerhoff wrote 05/21/2020 at 14:39 • point
hmm looks like you probably need to have a powered axis that the trucks pivot on  as well, this would be great because you could increase rideability by altering the max steering angle in relation to velocity, would really take the wobbly factor out, you will need to build a model to calculate the ideal angle limit curve, probably could do this by finding your CG and figure out angular momentum needed to move CG over centerline of the board to overcome forces applied while turning. its a great start though, and probably way easier than a CV solution
Adam Lange wrote 05/19/2020 at 16:52 • point
Now it's harder.  In the future it could be easier.  Balancing yourself on a skateboard with a thumb operated joystick is challenging but doable.  I have plans to strap a Vive lighthouse on the skateboard and implement a closed loop control.  Either you wear a tracker on your body or hold a tracker in your hand.  The control loop would try to keep the skateboard under the tracker and may include an offset from another comand source, for example a joystick.  A tracker on a stick would probably work well.
Krzysztof wrote 05/19/2020 at 07:47 • point
Would you say it's easier or harder to ride than normal skateboard?
Adam Lange wrote 05/19/2020 at 16:57 • point
Computer vision would also work well.  Probably better.  I would start with camera mounted on the skateboard looking up.  The driver would hold a visual target in their hand.  The control loop would try to keep the skateboard under the visual target.  In that same way you could make the skateboard follow things like your bicycle, other skateboards, ect.
Krzysztof wrote 05/20/2020 at 07:15 • point
Hmm, following bike - good idea for a "dog skateboard for transporting your groceries", but it would be probably too prone to tipping. But if it was a little wider platform... Overall, nice idea for steering!
My custom-built 900-degree racing wheel controller is designed to deliver the ultimate realistic driving experience.
Project Owner Contributor
900 Degree Racing Wheel Controller
rahel-zahir-aliRahel zahir Ali
Door handle game
Door Rider
tokakentokaken
New, better controller. Better motors. Improved mechanics.
Robotarm
volatile666volatile666
The 2018 Hackaday Prize
Remote controlled vehicle with two trailers is going reverse and steers automatically
Automatic reverse with two trailers
yuval-lombrozoyuval lombrozo
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "E-skateboard with torque vector steering", please tell us the reason.
Send message
Remove Member
