lel uds 19 mount.stl
A 3d-printable adaptor to mount the Lell UDS synth into a regular 19' rack
Standard Tesselated Geometry - 1.22 MB - 05/15/2020 at 20:31
Download
jack2din5.stl
An adaptor to fit regular jacks on this synth instead of soviet DIN-5 connectors
Standard Tesselated Geometry - 413.70 kB - 05/15/2020 at 20:28
Download
4mm shaft prolonger.stl
An adaptor to make the 4mm resistor shafts a bit longer to install different potentiometer knobs
Standard Tesselated Geometry - 743.29 kB - 05/15/2020 at 20:28
Download
