ON THE BOUNCE !
I will be using the torsion bar concept : This is a very compact and low maintainance suspension system.
I wil try to make an adjustable system, since I don't know the exact weight of the finished tank. It can also be useful to modify the initial strain to change the suspension behaviour if needed.
