Final code
06/02/2020 at 12:10 • 0 comments -
Controlling relay output
06/02/2020 at 12:07 • 0 commentsWhen the Rubik’s cube is completely solved, it activates the relay which in-turn activates the relay.
Moving servomotor as per clockwise or anti-clockwise rotation
06/02/2020 at 12:06 • 0 commentsWhen the Rubik’s cube top face rotates clockwise; the servomotor rotates clockwise and vice-versa.
Controlling servomotor (fixed rotation)
06/02/2020 at 12:04 • 0 commentsWhen the Rubik’s cube is completely solved, the servo motor start performing fixed rotation which can be coded in the firmware.
Blinking LED for 5 second
06/02/2020 at 12:02 • 0 commentsWhen the Rubik’s cube is completely solved, the led is activated. I did not have led to test this experiment so I planned to use led from relay.
PREREQUISITES and MAC ID of Rubik's Cube
06/02/2020 at 11:59 • 0 commentsPREREQUISITES
- Arduino IDE with ESP32 core installed
- Basic terminology about BLE, service, and characteristics
- nrfConnect Nordic App
MAC ID OF RUBIX CUBE
Open nrfconnect APP and twist the Rubik’s cube. MAC ID will be displayed directly on nrfconnect app.
Dhiraj Gehlot
