I am using a: Shopbot PRSalpha 96-60
Let me know of any additions, corrections, or clarifications that you might suggest or need!
Protect your ears from face mask ear loop burn!
EarSaverShopbotSetup_26inches.crvcrv - 29.74 MB - 05/19/2020 at 00:17 |
EarSaverShopbotSetup_20inches.crvcrv - 22.31 MB - 05/19/2020 at 00:17 |
EarSaverSingle_Spacer_Text.dxfAutoCAD DXF - 767.42 kB - 05/19/2020 at 00:17 |
EarSaverSpoilboardSetup_18x26inches.crvcrv - 33.00 kB - 05/19/2020 at 00:17 |
EarSaverSheet_20inchMaterial_24parts.dxfAutoCAD DXF - 13.94 MB - 05/19/2020 at 00:16 |
FYI - I had several issues exporting a fully correct Surfacing File from Vcarve. But eventually got it, just make sure to check your code before you get infront of the machine.
I used an off-cut as a strait edge to align the "Even" Bottom sides of the materials.
Use a Sanding Block on the surface of the Spoilboard after each sheet.
The Scotch tape DID work! But only on a clean spoilboard surface.
Cut through all the columns of your parts; 8 minutes
Cut only one column at a time, to remove any tape residue from the endmill, and incase something goes wrong...; 2 minutes
I usually get through three sheets before I've needed to surface the board
