1VCarve: First Pass- Cut through the Top .050" Layer of the parts
Cut through all the columns of your parts; 8 minutes
2VCarve: Second Pass- Cut through the Bottom .095" Layer of ONE Column at a time
Cut only one column at a time, to remove any tape residue from the endmill, and incase something goes wrong...; 2 minutes
3Double Stick tape the material to the Spoilboard
I usually get through three sheets before I've needed to surface the board
