LoRa_PingPong.zipThis is the modified (with sound) Arduino LoRa ping pong example for m10sensor as shown on imageZip Archive - 3.71 kB - 01/14/2021 at 13:06 |
m10cube.pngThis is the Box where M10CUBE sits on. The files are redesigning and soon will be uploaded into GitLABPortable Network Graphics (PNG) - 179.66 kB - 10/02/2020 at 17:07 |
m10cube conventions.txtThat is the new naming convention introduced in 09/2020 since M10CUBE is becoming extremely complicated to handle the different boards now and in futureplain - 784.00 bytes - 10/02/2020 at 11:04 |
M10PR03-01.pngPrototype module. This is located as a bottom PCB together with the Raspberry Pi 4 and PSU module. These 3 modules define the CPU FramePortable Network Graphics (PNG) - 191.39 kB - 10/02/2020 at 10:43 |
M10DX01-01.pngDigital Input Output modulePortable Network Graphics (PNG) - 143.13 kB - 10/02/2020 at 10:43 |
M10SE01-01.pngSensor modulePortable Network Graphics (PNG) - 144.13 kB - 10/02/2020 at 10:43 |
M10PS01-01.pngPower Supply Unit. This is located as a middle PCB together with the Raspberry Pi 4 and Prototype module. These 3 modules define the CPU FramePortable Network Graphics (PNG) - 95.54 kB - 10/02/2020 at 10:43 |
M10DO01-01.pngDigital Output modulePortable Network Graphics (PNG) - 89.63 kB - 10/02/2020 at 10:43 |
M10SE01-01-PCB-TOP.pngSensor PCB TOPPortable Network Graphics (PNG) - 68.67 kB - 10/02/2020 at 10:43 |
M10PR03-01-PCB-TOP.pngPrototype PCB TOPPortable Network Graphics (PNG) - 91.52 kB - 10/02/2020 at 10:43 |
M10DX01-01-PCB-TOP.pngInput Output PCB TOPPortable Network Graphics (PNG) - 52.90 kB - 10/02/2020 at 10:43 |
M10PS01-01-PCB-TOP.pngPSU PCB TOPPortable Network Graphics (PNG) - 27.63 kB - 10/02/2020 at 10:43 |
M10DO01-01-PCB-TOP.pngDigital Output PCB TOPPortable Network Graphics (PNG) - 48.31 kB - 10/02/2020 at 10:43 |
readme.txtAll project files can be found in GitLab https://gitlab.com/m10cube/m10plain - 72.00 bytes - 05/27/2020 at 18:43 |
VASILIS VORRIAS
