PCB enclosure
06/02/2021 at 05:46 • 0 comments -
Armachat - Cyberdeck style preview
10/04/2020 at 20:51 • 0 comments -
New user interface, new meshtastic compatible protocol
09/20/2020 at 11:13 • 0 commentsCleaning code ... unifying user interface, rewriting communication, power saving
Something what is finished now
- Switching to white background, maybe it is bad step, but why wasting light
you can change black/white theme in setup - New font something middle between old small/big combination
- User name is auto updated in contact lists on all remote units.
- Addressing and protocol adapted for future #meshtastic support.
- Soon you can send message to #meshtastic network, they nodes forward this message to another Armachat unit, but you can not read this message on Meshtastic app :(
- Also working on adaptation Meshtastic mesh routing protocol for armachat (Full interconnection is little hard, but maybe in far future I want this)
Power management
I am searching way how to reduce consumption but I found only one way ... reduce backlit
- MCU 20mA
- LoRa 10mA
- Backlit 30mA
Total 60mA, if I switch-off lora, there is no receiving wake up.
If MCU go to sleep, display freeze.
Lowering backlight (no switch-off just to 10%)
I can go to 30mA with full runtime a little readable display
Next you can compare user interface (Black unit - OLD. Green unit - NEW UI)MAIN SCREEN
ADDRESS BOOK
TEXT EDITOR
SETUP
Next distance test ... little above 4km
09/13/2020 at 19:28 • 0 commentsToday I make small bike trip to next village.
New distance test ... above 4km.- 865,2Mhz
- LoRa SpreadFactor 12
- 3 dbi antenna
- one unit in attic window, second in hand.
- No direct view, some small hills and houses
Not reliable, I need some walking and search.
Poll for protocol finished, Meshtastic is winner ;) Yesterday I started protocol adaptation. I am not sure if I can fully implement routing in to Armachat device but I want negotiate with Meshtastic authors about injecting packet to Meshtastic network and then forward with they nodes.
For now I am very satisfied. I think connection to 2km is very reliable.
I can imagine solution with only one simple repeating node above hill or church and cover large area with lot of users.
Mesh protocol Meshtastic or Disaster.radio ???
09/11/2020 at 06:11 • 2 commentsI created poll about future mesh protocol implemntation.
YOU CAN VOTE HERE>>> https://twitter.com/bobricius/status/1302689102970662913
Gold/Green boards with keyboard backlight
09/07/2020 at 22:27 • 0 comments -
Armachat - Distance test
07/30/2020 at 20:11 • 0 commentsFinally I get time to make small distance test, no direct view, between houses in village.
700-1500m ... maybe more, standard RFM95 20dB output, spread factor 12, 2dB antenna- Unit on garden desk
- Unit in window, about 4m above ground
Cyberdeck style concept.
07/03/2020 at 10:47 • 2 commentsIt is waterproof box for memory cards.
I need design separated keyboard and main board.
Of course it is still not doomsday resistant. just for fun ;)![]()
RFM95PW - High Power radio module and IPS display
06/29/2020 at 21:10 • 0 commentsDescriptions of RF LoRa Transceiver Module RFM95PW:
RFM98PW/RFM95PW RF LoRa Transceiver module series’ design is based on the high performance LoRaTM modulation technique RF98/RF96 chip, It operate at 169/433/470MHz (RFM98PW) and 868/915MHz(RFM95PW) ISM band , The low receive sensitivity(–136dBm) coupled with Enhanced +30dBm output power ensures extended range and improved link performance.
240x240 IPS display and square buttons :)
You can also use bigger TFT display.
RFM95PW under module is footprint for clasic RFM95, also on board is optionall DS3231 with backup battery.
Received new boards
06/03/2020 at 22:33 • 0 commentsNEWS:
- Routing new board with higher power module RFM95 design is almost ready for factory.
- Board is little smaller as previous version (-10mm) 62mm x 77mm
- Accepting both RFM95 and RFM95PW lora modules
- Maybe is wearable with realy comfort keyboard and bigger display ( Armawatch killer ??? ).
bobricius
