1General Overview
1) As I cannot share all of the data I put a small portion of it in the Jupyter Notebook in my github.
Step 1: Set up the sensors at the incoming power node and in the rooms. It is a serial based sensor so, tie it to a software serial and push the data to cloud using an ESP32.
Step 2: Download the feed from the cloud platform to use the data to train your AI
Step 3: Clean the data by filling NAN's and other improper data.
Step 4: Set all the elements in the data to float64 as the computations are mostly floating point and are very small so we need good precision.
Step 5 : Find the optimal values
Step 6 : Train your ANN
Step 7 : Deploy your application
Step 8 : After a month deploy a LSTM trained on the collected data for the entire duration and deploy your LSTM.
This is a brief description of the project.
srimanthtenneti
