1Step 1: Components
The required components are:
- Arduino Uno / Nodemcu
- Jumper Wires
- Speaker/Buzzer
- BC547 Transistor (optional)
- Led (optional)
2Step 2: Arduino Connection With Speaker
Arduino with speaker
here I have used bc547 transistor as amplifier for the speaker
3Step 3: Arduino Connection With Buzzer
Arduino With Buzzer
4Step 4: Arduino Code For Astronomia
Coffin Dance Arduino Code
Astronomia codefor Arduino is given below.
Copy the below code and paste it in Arduino IDE then upload to the Arduino board.
#define NOTE_B0 31 #define NOTE_C1 33 #define NOTE_CS1 35 #define NOTE_D1 37 #define NOTE_DS1 39 #define NOTE_E1 41 #define NOTE_F1 44 #define NOTE_FS1 46 #define NOTE_G1 49 #define NOTE_GS1 52 #define NOTE_A1 55 #define NOTE_AS1 58 #define NOTE_B1 62 #define NOTE_C2 65 #define NOTE_CS2 69 #define NOTE_D2 73 #define NOTE_DS2 78 #define NOTE_E2 82 #define NOTE_F2 87 #define NOTE_FS2 93 #define NOTE_G2 98 #define NOTE_GS2 104 #define NOTE_A2 110 #define NOTE_AS2 117 #define NOTE_B2 123 #define NOTE_C3 131 #define NOTE_CS3 139 #define NOTE_D3 147 #define NOTE_DS3 156 #define NOTE_E3 165 #define NOTE_F3 175 #define NOTE_FS3 185 #define NOTE_G3 196 #define NOTE_GS3 208 #define NOTE_A3 220 #define NOTE_AS3 233 #define NOTE_B3 247 #define NOTE_C4 262 #define NOTE_CS4 277 #define NOTE_D4 294 #define NOTE_DS4 311 #define NOTE_E4 330 #define NOTE_F4 349 #define NOTE_FS4 370 #define NOTE_G4 392 #define NOTE_GS4 415 #define NOTE_A4 440 #define NOTE_AS4 466 #define NOTE_B4 494 #define NOTE_C5 523 #define NOTE_CS5 554 #define NOTE_D5 587 #define NOTE_DS5 622 #define NOTE_E5 659 #define NOTE_F5 698 #define NOTE_FS5 740 #define NOTE_G5 784 #define NOTE_GS5 831 #define NOTE_A5 880 #define NOTE_AS5 932 #define NOTE_B5 988 #define NOTE_C6 1047 #define NOTE_CS6 1109 #define NOTE_D6 1175 #define NOTE_DS6 1245 #define NOTE_E6 1319 #define NOTE_F6 1397 #define NOTE_FS6 1480 #define NOTE_G6 1568 #define NOTE_GS6 1661 #define NOTE_A6 1760 #define NOTE_AS6 1865 #define NOTE_B6 1976 #define NOTE_C7 2093 #define NOTE_CS7 2217 #define NOTE_D7 2349 #define NOTE_DS7 2489 #define NOTE_E7 2637 #define NOTE_F7 2794 #define NOTE_FS7 2960 #define NOTE_G7 3136 #define NOTE_GS7 3322 #define NOTE_A7 3520 #define NOTE_AS7 3729 #define NOTE_B7 3951 #define NOTE_C8 4186 #define NOTE_CS8 4435 #define NOTE_D8 4699 #define NOTE_DS8 4978" int melody[] = { NOTE_A4, 0, NOTE_A4, NOTE_A4, NOTE_C5, 0, NOTE_AS4, NOTE_A4, NOTE_G4,0, NOTE_G4, NOTE_AS5, NOTE_A5, NOTE_AS5, NOTE_A5, NOTE_AS5, NOTE_G4,0, NOTE_G4, NOTE_AS5, NOTE_A5, NOTE_AS5, NOTE_A5, NOTE_AS5, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_AS4, NOTE_D5, NOTE_D5, NOTE_D5, NOTE_D5, NOTE_C5, NOTE_C5, NOTE_C5, NOTE_C5, NOTE_F5, NOTE_F5, NOTE_F5, NOTE_F5, NOTE_G5, NOTE_G5, NOTE_G5, NOTE_G5, NOTE_G5, NOTE_G5, NOTE_G5, NOTE_G5, NOTE_G5, NOTE_G5, NOTE_G5, NOTE_G5, NOTE_C5, NOTE_AS4, NOTE_A4, NOTE_F4, NOTE_G4, 0, NOTE_G4, NOTE_D5, NOTE_C5, 0, NOTE_AS4, 0, NOTE_A4, 0, NOTE_A4, NOTE_A4, NOTE_C5, 0, NOTE_AS4, NOTE_A4, NOTE_G4,0, NOTE_G4, NOTE_AS5, NOTE_A5, NOTE_AS5, NOTE_A5, NOTE_AS5, NOTE_G4,0, NOTE_G4, NOTE_AS5, NOTE_A5, NOTE_AS5, NOTE_A5, NOTE_AS5, NOTE_G4, 0, NOTE_G4, NOTE_D5, NOTE_C5, 0, NOTE_AS4, 0, NOTE_A4, 0, NOTE_A4, NOTE_A4, NOTE_C5, 0, NOTE_AS4, NOTE_A4, NOTE_G4,0, NOTE_G4, NOTE_AS5, NOTE_A5, NOTE_AS5, NOTE_A5, NOTE_AS5, NOTE_G4,0, NOTE_G4, NOTE_AS5, NOTE_A5, NOTE_AS5, NOTE_A5, NOTE_AS5 }; // note durations: 4 = quarter note, 8 = eighth note, etc.: int noteDurations[] = { 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, 4,4,4,4, }; void setup() { for (int thisNote = 0; thisNote < 112; thisNote++) { int noteDuration = 750 / noteDurations[thisNote]; tone(7, melody[thisNote], noteDuration); int pauseBetweenNotes = noteDuration * 1.30; delay(pauseBetweenNotes); noTone(7); } } void loop() { }
