Out of curiosity, I took a look at what other people were doing for this contest. I was inspired by this project log in the Nanodrone project. In the link below, the author designed a case for 3D printing.
I wanted to do something similar but I didn't have a 3D printer. And also all the Makerspace facilities near my home are closed due to the coronavirus situation. I decided to create a paper craft version of it. I can print it on colored stock paper.
Final Design of Paper Craft Enclosure
Thus, here is my design for the paper craft enclosure for the Cypress PSoC® 6 WiFi-BT Pioneer Kit (CY8CKIT-062-WiFi-BT).
The original files can be found open-source on my github repository. Feel free to download it and make one yourself!
![](https://cdn.hackaday.io/images/8724281595067689026.png)
![](https://cdn.hackaday.io/images/4578121595067808614.png)
Initial prototype using paper
![](https://cdn.hackaday.io/images/6233121595075099892.jpg)
![](https://cdn.hackaday.io/images/6387531595075099359.jpg)
![](https://cdn.hackaday.io/images/1615501595075099391.jpg)
Final prototype using card stock
![](https://cdn.hackaday.io/images/9818111595075227469.jpg)
![](https://cdn.hackaday.io/images/1469451595075276035.jpg)
![](https://cdn.hackaday.io/images/1523631595075294624.jpg)
![](https://cdn.hackaday.io/images/3338701595075306117.jpg)
![](https://cdn.hackaday.io/images/8267261595075318834.jpg)
Ha! Thank you for citing the project!. I was just writing that regardless of the material (I am a fan of cardboard and I have done a whole series of cardboard projects for STEM articles), you got better and more precise measures. I think my design has a couple of mistakes I will correct for a new 3D printed version based on your very precise and well done design!
Cheers. Enrico
Thanks for checking in on my project! I was inspired by your design but I wanted the casing to a tighter fit to the board, so I added a "step" to the part after the LCD display. My final prototype used 200gsm A4 paper.
I would love to see your new 3D design. I hope to print your design in the future when I have access to a 3D printer.
