The little daughter boards arrived from JLCPBC and the quality is excellent. Although the simplest board ever, with costs so low these days, I thought I'd check out JLCPCB and keep things tidy at the same time...
Tested code on Git and as I manage to reverse the LCD connector, I used some ribbon cable instead of soldering the LCD directly (which also has some advantages)... everything is working fine so far...
