Renders, Renders everywhere
07/08/2020 at 02:19 • 0 comments -
the most recent "Final" version
07/08/2020 at 02:18 • 0 comments -
Meet the tiny USB power supply
07/08/2020 at 02:17 • 0 commentsThis is a micro usb stop up converter from amazon, then I added two capacitors to solder in parallel with the in and out connections. The variable resistor trims the voltage up or down I think up to 20 volts and min 2 volts above input voltage.
adjusted logo plate
07/08/2020 at 02:15 • 0 comments -
Print , adjust the logo print agian
07/08/2020 at 02:15 • 0 commentsI needed to adjust the logo by making the S thicker, and printed vertically in .2 mm resolution this next time.
Ok time to print agian
07/08/2020 at 02:13 • 0 comments -
New tray and body slightly larger
07/08/2020 at 02:13 • 0 commentsThe body is 1-2 mm thicker now and there are cut outs for the capacitors to have room. The tray is now deeper to allow extra clearance from the solder joints and pins on the bottom of the PCB.
The Highs, the Lows and the off Center
07/08/2020 at 02:11 • 0 commentsMarking high and lost spots to center the micro usb connector. Also the two caps I added needed some space to breath.
3d modeling starts , this is Ver 3
07/08/2020 at 02:09 • 0 comments -
Measuring and sketching
07/08/2020 at 02:07 • 0 comments
