![](https://cdn.hackaday.io/images/6713261590314260162.jpg)
![](https://cdn.hackaday.io/images/7847971590314361957.jpg)
We take the cover of the box and made some things on it.
![](https://cdn.hackaday.io/images/5511681590314522897.png)
Every piece has been made to easily be removable. The motor Knob can be used when the machine is powered off to clamping the abu-bag between the two squeezers.
![](https://cdn.hackaday.io/images/5845831590314827124.png)
The spring system can be easily removed
![](https://cdn.hackaday.io/images/2665711590314941494.png)
