Identifying connection points
A project log for Neato D-Series Lidar and Raspberry Pi 3A+ with ROS
Working towards an autonomous mech warfare robot. (2020)
gertlexGertlex 06/06/2020 at 20:070 Comments
To connect to the laser, we need to identify what pins or test points to solder or otherwise connect wires to.  Based on hearsay, the expectation was that the same interface as the XV11 Lidars was still in place:
The interface board, shown below, is also an interface for several other components on the vacuum: wheel motors, wheel encoders and speakers.
To jump straight to results, the following were identified and relevant:
Less relevant:
