1Pictures and sounds
- Pick various animal pictures from the internet and print them on A4 sheets.
- Take a big transparent protective sheet and tape the pictures under
- Tape the corner so it will hold on the DDR mat.
- Pick up the corresponding animal sounds and copy them in <script directory>/sounds and rename them as 1...9.wav
- Make the script executable and run it : chmod u+x musicmat.py ; ./musicmat.py
PixJuan
