SC84-MCOS-from-disassembly-source.txt
The OCR bytes disassembled and reverse engineered into a form that re-assembles into the OCR bytes.
plain - 33.15 kB - 06/17/2022 at 22:32
Download
diff-memdump-bytes-and-OCR-bytes.txt
Differences between memdump bytes and OCR bytes.
There are some, but not due to OCR errors.
Probably due to self-modifying code.
plain - 611.00 bytes - 06/17/2022 at 20:12
Download
SC84_MCOS_from_memory_dump.txt
Source code recreated from hex data from a live memory dump.
plain - 14.56 kB - 06/17/2022 at 20:05
Download
SC84_MCOS_from_memory_dump.txt.hex
A hex file for comparison with the OCR bytes.
hex - 5.51 kB - 06/17/2022 at 20:05
Download
SC84-MCOS-from-OCR-hex-source-txt.txt
Source code recreated from hex data from OCR scans from newsletter. First 18 bytes disassemble to a copy-and-jump routine. Scraps of source code from various documents.
plain - 19.37 kB - 06/17/2022 at 20:05
Download
SC84-MCOS-from-OCR-hex-source-txt.hex
A hex file for comparison with the memory dump bytes.
Download
SC84-MCOS-hex-source.txt.lst.txt
Added .txt to filename so it can be read online.
Not all browsers understand *.lst is a text file.
plain - 161.92 kB - 06/17/2022 at 13:00
Download
wsovly1_ovr.bin
WordStar Overlay v3.00 1980 Micropro International - patched for SC84/SCIDOS (super-fast VDU access)
octet-stream - 33.50 kB - 04/06/2021 at 21:28
Download
wsmsgs_ovr.bin
WordStar MSGS-Overlay v3.00 1980 Micropro International - patched for SC84/SCIDOS (super-fast VDU access)
octet-stream - 24.00 kB - 04/06/2021 at 21:28
Download
ws_com.bin
WordStar v3.00 1980 Micropro International - patched for SC84/SCIDOS (super-fast VDU access)
octet-stream - 15.75 kB - 04/06/2021 at 21:28
Download
mbasic_com.bin
BASIC-80 CP/M v 5.2 14-Jul-80 - Microsoft
octet-stream - 23.88 kB - 04/06/2021 at 21:26
Download
basic_com.bin
Expanded Disc Basic v 1.0d - SCITEX
octet-stream - 17.50 kB - 04/06/2021 at 21:24
Download
bas_com.bin
Extended Disc Basic v 2.2a - SCITEX
octet-stream - 11.50 kB - 04/06/2021 at 21:24
Download
seldsc_com.bin
Redefines format for drive B: to formats used by other systems
octet-stream - 640.00 bytes - 04/06/2021 at 21:14
Download
rep_com.bin
A fast single drive copier using the Silicon Disc as intermediate media (ideal for mass copying/distributing discs)
octet-stream - 1.00 kB - 04/06/2021 at 21:11
Download
sysgen_com.bin
Copies/clones the SCIDOS system tracks to another disc
octet-stream - 640.00 bytes - 04/06/2021 at 21:09
Download
sub_com.bin
Executes a series of commands without operator involvement as per xxx.sub file (similar to DOS batch xxx.bat)
octet-stream - 1.00 kB - 04/06/2021 at 21:07
Download
stat_com.bin
Displays free space of currently logged discs,as well as number of files etc.
octet-stream - 3.88 kB - 04/06/2021 at 21:05
Download
p_com.bin
Send pre-defined control sequences to EPSON printers
octet-stream - 1.00 kB - 04/06/2021 at 21:03
Download
pip_com.bin
"Peripheral Interchange Program": transfers data between different I/O channels (e.g. transfer files between discs)
octet-stream - 5.75 kB - 04/06/2021 at 21:01
Download
debug_com.bin
Check/debug/correct .com programs by single-step or by defining break-points or pass-points
octet-stream - 6.88 kB - 04/06/2021 at 20:58
Download
edit_com.bin
Edit disc sectors in SCIDOS environment
octet-stream - 4.00 kB - 04/06/2021 at 20:57
Download
ddisc5_com.bin
Direct read or write disc access tool from system memory
octet-stream - 512.00 bytes - 04/06/2021 at 20:55
Download
dcopy540_com.bin
Very fast disc to disc copier/cloner 5,25" DD 40 track
octet-stream - 1.25 kB - 04/06/2021 at 20:53
Download
dcopy5_com.bin
Very fast disc to disc copier/cloner 5,25" DD 80 track
Download
flush_com.bin
Initialises (formats) the Silicon Disc drive E: (it actually clears the directory area needed after power-on)
octet-stream - 256.00 bytes - 04/06/2021 at 20:50
Download
df51_com.bin
Format and check single track 5,25" DD floppy disc
octet-stream - 768.00 bytes - 04/06/2021 at 20:48
Download
dform540_com.bin
Format and check 5,25" DD 40 track floppy disc
octet-stream - 768.00 bytes - 04/06/2021 at 20:47
Download
dform5_com.bin
Format and check 5,25" DD 80 track floppy disc
octet-stream - 768.00 bytes - 04/06/2021 at 20:46
Download
scidos_doc.txt
SCIDOS operating system manual - version 2.1D
plain - 42.12 kB - 04/06/2021 at 20:44
Download
20210324 SCIDOS Floppy System tracks 0 and 1 v2.txt
Hexdump of the 2 system tracks containing bootstrap and SCIDOS with description of the actual boot sequence.
plain - 53.44 kB - 03/24/2021 at 11:29
Download
20210324 Active SCIDOS and MCOS memory dump.txt
Memory dump of working system indicating memory locations of SCIDOS BDOS and MCOS.
plain - 42.69 kB - 03/24/2021 at 11:07
Download
SC84-VDU-font.txt
Source code will assemble the font ROM data.
Verified - creates same data as original ROM.
text/plain - 55.78 kB - 03/22/2021 at 20:53
Download
JPEG Image - 1.05 MB - 03/20/2021 at 11:50
Preview
JPEG Image - 1.51 MB - 03/20/2021 at 11:50
Preview
JPEG Image - 1.41 MB - 03/20/2021 at 10:17
Preview
JPEG Image - 1.31 MB - 03/20/2021 at 10:17
Preview
JPEG Image - 1.06 MB - 03/20/2021 at 10:17
Preview
SCITEX BASIC 1 with OCR.pdf
BASIC manual 1, dated 1982
Adobe Portable Document Format - 727.71 kB - 03/19/2021 at 13:56
Preview
SCITEX BASIC 2 with OCR.pdf
BASIC manual 2, dated 1984
Adobe Portable Document Format - 487.85 kB - 03/19/2021 at 13:56
Preview
SC84_VDU_ChrGen_eprom.bin
Copy of original EPROM (working version on VDU card)
octet-stream - 4.00 kB - 03/19/2021 at 10:38
Download
SC84_CPU_MCOS_eprom.bin
Copy of original EPROM (working version on CPU card).
Diverges from the hex dump in newsletter volume 1 number 2 at location 65B hex.
octet-stream - 8.00 kB - 03/19/2021 at 10:38
Download
SC84 newsletter volume 1 number 2.html.zip
SC84 newsletter volume 1 number 2, converted to html.
It has a hex dump of the MCOS firmware! :-)
Zip Archive - 389.60 kB - 03/17/2021 at 16:26
Download
Wireless-World-1985-10-pages-35-36-and-93.pdf
Half-megabyte memory for SC84
Adobe Portable Document Format - 206.28 kB - 03/17/2021 at 15:36
Preview
Wireless-World-1984-05-pages-37-40-and-51.pdf
SC84 part 1
Adobe Portable Document Format - 401.49 kB - 05/31/2020 at 18:23
Preview
Wireless-World-1984-06-pages-39-42.pdf
SC84 part 2
Adobe Portable Document Format - 404.96 kB - 05/31/2020 at 18:23
Preview
Wireless-World-1984-09-pages-51-53-and-63.pdf
SC84 construction tips
Adobe Portable Document Format - 396.05 kB - 05/31/2020 at 18:23
Preview
MK3801_datasheet_scans.zip
Mostek MK3801 datasheet scans
Zip Archive - 2.42 MB - 07/03/2020 at 00:31
Download
