Shredder.FCStd
Stand in for a aluminum soda can shredder. I'm trying to keep this to parts that anyone, anywhere can source themselves. In this case, I used the dimensions for commonly available leaf spring steel. Which is hardened and tempered. 80mm wide by 7mm thick. It'll need to be cut to 100mm to 107mm and welded together. However, the gears and a method for shredding the soda cans are both something I'm still trying to figure out.
application/x-zip-compressed -
60.08 kB -
06/02/2020 at 06:06
