This is the first STL of a printable half of an enclosure. Don't print it - for info only. If it works, then a mirrored version is required for the other half. After that, a nice front plate to mount the driver is required along with a stand. And if all that works, a collection of files will be available for anyone else with similar drivers. Presumably it would be simple to generate a new front plate for any 2" or 3" driver. Such thoughts will be mulled later.
Standard Tesselated Geometry -
2.12 MB -
05/27/2020 at 17:07
The crossover, drawn up in SiMetrix. There's a limited node version of SiMetrix available free. It's great. Also, I learnt it ages ago and I don't like change. Change is bad!
