i. Concept- Is the project creative, original, functional, and pushing boundaries? Does the project effectively address the selected challenge?
Yes the project has a solid Cerebral Palsy foundation theme, this was build with feedback from the mentors that communication and emotional expression is tough for cerebral palsy individuals
ii. Design- Is there a depth of design detail available (like a system design, CAD models, project test methods, etc.)? Is there base-level planning for the functionality (e.g., functional block diagram, list of specifications and descriptions of how they will be met, etc.)? How user-friendly is the design?
I will create a plan for the process and get some test models out for the cerebral palsy foundation to try out.
NEEDS IMPROVEMENT
iii. Production- Is the project realistically reproducible (taking into consideration necessary materials, skills, and production processes)? Are the manufacturing processes detailed? Are those processes realistic for scalability?
The style of manufacturing is certainly possible in any maker space. Vacuum forming does not require expensive equipment and duplicate blanks for mask frames can be make every few minutes when you get going.
iv. Benchmark- How well is the project impact and viability demonstrated? Are estimated costs realistic? How well does the project improve upon other currently available solutions?
I will demonstrate the product on myself and also send prototypes to the foundation for testing in the real world for feedback.
NEEDS IMPROVEMENT
v. Communication- How thoroughly have the Final Round requirements been completed? How well documented is the project? How “open” is the design?
NEEDS IMPROVEMENT
Josh Starnes
John Baichtal
Tobias
It is a new project, the first project is just a clear mask by itself , one and done. the only one piece from the other project is an outer frame and that was just the first set of pictures to get and idea of what it might look like , then I went back to the drawing board because the needs of this project are different. Once COVID has passed the project needs to still be valid and usable which is why this project will include alternate ways to mount lighting to a pole on their chair or the parameter of their table trays that commonly clip on to their specialized chairs. It is significantly different in the case that a physical controller must be developed that will control and RGB setup, house the batteries, physically large format and robust to survive drops and make it easy to use in a way that is designed in mind for a cerebral palsy individual. See the first project was just a clear mask made to be vacuum formed with quality and cheapness. So just to be clear , the 3D files and STLs for each project are different as well . A completely different design will be required. This is easily going to be 300% the work the clear N95 mask project requires. In the next couple build logs you will see how this projects efforts and challenges lie within the electronics, adaptive control and possibly an app for Android/ IOS tablets. The pictures I have up know are fun looking click bait to get hacksters to start reading and hopefully inspired , for a good cause, to build their own ideas. I can see where you would misunderstand the scope of the project , perhaps I will explain it better in the description. Thank You , Josh
