V005.zip
The network driver code - takes the raw input from the array and converts it to ASCII hex for the Java to read. Also has a "Log" version just for logging data to a file instead of streaming into a fifo. You will also have to increase the default MTU (maximum transmission unit), which is 1500 or something by default. Meaning packets have to be less than 1500 bytes or they'll be dropped by the network driver or something. The array sends 2400 byte packets, so you have to increase this, I went up to 4000.
x-zip-compressed -
1.78 MB -
06/02/2020 at 01:46
Download
C009_MultiImages.zip
Processing sketch to do real-time imaging. Requires the network driver to be running at the time as well to work, OR, a logfile to be piped into the FIFO. You'll first have to make a fifo using mkfifo (I called mine /home/john/pipe, it's hadcoded near the end of the file). If you just run a file cat Logfile.log > /home/john/pipe while this is running this should work
x-zip-compressed -
97.71 kB -
06/02/2020 at 01:38
Download
PAR_03_ALLBOARDS.zip
the FPGA firmware
x-zip-compressed -
3.15 MB -
05/29/2020 at 23:33
Download
Reflection.mp4
Video showing acoustic reflection off of a piece of acrylic
MPEG-4 Video -
34.65 MB -
05/29/2020 at 23:19
Download
odds_medium_moving.avi
Moving speaker in front of the array
Audio Video Interleave (AVI) -
17.69 MB -
05/29/2020 at 23:17
Download
evens_moving_2.avi
4.16 MB -
05/29/2020 at 23:16
Download
V004_main.m
MATLAB code for doing post-processing on data from the array
m -
36.52 kB -
05/29/2020 at 23:15
Download
JPEG Image -
7.70 MB -
05/29/2020 at 23:15
Preview
VID_20200501_195746.mp4
MPEG-4 Video -
12.20 MB -
05/29/2020 at 23:15
Download
JPEG Image -
4.14 MB -
05/29/2020 at 23:14
Preview
