wilson_mindearpiece2_ETgxBBbnMb.stlEar Piece 2Standard Tesselated Geometry - 604.67 kB - 05/31/2020 at 22:35 |
wilson_mindearpiece1_CTPHL9Ygb1.stlEar Piece 1Standard Tesselated Geometry - 818.44 kB - 05/31/2020 at 22:35 |
kairosu_ft82g3bxND.pngEyetracking SchematicIncludes the PSEye, the ring of infrared LEDs, and the Arduino. This was taken from http://hikarielectronics.blogspot.com/ which details how to build the Eyewriter 2.0 with the PSEye camera. Portable Network Graphics (PNG) - 91.40 kB - 05/31/2020 at 22:35 |
wilson_mindbox_Fta1h2gl7a.stlConsole HousingStandard Tesselated Geometry - 327.62 kB - 05/31/2020 at 22:35 |
wilson_mindboxtop_QAqfyHvvIU.stlTop LidCentral Console Top Enclosure Standard Tesselated Geometry - 241.20 kB - 05/31/2020 at 22:35 |
ew_hwfullschematic_Q1IJVceXD3.jpgEyewriter SchematicFrom the Instructables Eyewriter 2.0, we obtained and used this schematic along with the one from Hikari Blogspot to build our eye tracker. JPEG Image - 97.88 kB - 05/31/2020 at 22:35 |
integrator_cpp.cThis code provides basic integration of gyro data to derive the total number of degrees turned. This is a helper file that was written separately.plain - 4.72 kB - 05/31/2020 at 22:35 |
arduino_programming.inoThis code runs on the microcontroller to carry out the maneuvers required to treat BPPV Vertigo.ino - 21.02 kB - 05/31/2020 at 22:35 |
vertifix_4netXe1qyd.pdfManeuvers SchematicAdobe Portable Document Format - 28.82 kB - 05/31/2020 at 22:35 |
integrator_h.cThis code provides basic integration of gyro data to derive the total number of degrees turned. This is a helper file that was written separately.plain - 773.00 bytes - 05/31/2020 at 22:35 |
