Ch55xduino
Back to overview
You can simply write code in Arduino IDE and hit one button to flash the ch55x chip to get code running.
ilo wrote 06/04/2023 at 19:56 • point
Good job !!!!
biemster wrote 03/08/2023 at 14:04 • point
To enter the bootloader first time on a CH552G (which is running the show on a mini macropad), connecting a pull-up between the D+ line and pin 16 (3v3) did not work. There is an alternative way though, which is pulling pin 3 to ground. (connect pin 14 and pin 3 together). That worked!
Found that gem here: http://rabid-inventor.blogspot.com/2020/05/getting-started-with-ch55x.html
deqing wrote 03/08/2023 at 14:10 • point
It is likely the manufacturer of your macropad changed the configuration bit. The new chip should use the D+ line. But it can be changed.
biemster wrote 03/08/2023 at 14:16 • point
You mean it is either D+ to 3v3, or pin3 to gnd?
Oddly the pad had nicely adjacent test points to connect D+ and pin16 with a 10k already in place :) That was a nice trick to confuse me
