After observing the PLL performance over several days it became obvious that both the tracking accuracy and the loop stability could be improved. As a result I made the following changes:
- Added logging of PLL frequency correction.
- Increase effective DAC resolution to 16 bits through offset twiddling.
- Reduce PLL overshoot by applying adaptive gain based on error magnitude.
- Fix offset in error estimation by shifting clock bins 0.5 cycles to match ideal signal alignment.
Before:
After:
