This feels like a slight pivot, but I will do my best to keep the project true to its roots, affordable and 3d printed.
I dug up an old anet a8 metal frame, AM8. Initially I thought extrusion wouldn't be good for this, but it was merely the 8mm rods that were insufficient. I plan to use the 1/2 and 3/4 steel tubes (*are tubes suitable or must it be rod?) and bronze bushings. I found inexpensive $1.50 tube holders that will work as shaft holders and bearing holders. Another idea is to do a press fit for the shaft into the aluminum, but I don't think I can drill that accurately. I'll still drill the frame a bit, but it'll likely just be to extend the rods and be held with a 3d printed rod holder. There is also a possibility of brazing everything rigid. One thing I noticed about aluminum extrusion is barely anyone is using an anchor fasteners. Mostly through holes and 90* fasteners and I suspect the anchor makes it a much more sold structure. Avid CNC uses anchor fasteners for their machines. I'm going to use them on this. Perhaps even test the difference between anchor fasteners and other options.
Elliot
