The system is oriented mainly to obtain images of the human torax cavity since the gradient of resistance is bigger there because of the air inside the lungs. It is also known that detailed images of the lungs are needed to help in the diagnosis of covid19, probably this system is more suitable for detect higher variations in electric resistivity as can be a lung partially filled with liquid.
The measurement of resistance in living beings is complex due to the presence of natural electric potentials. This is overcome using a tool capable of measure resistance neutralizing mathematically the natural electric potentials in each measurement.
Nguyen Khanh Tung
DARK-labs
Sam
Hi
Thanks for your question.
I has been working with other applications of electric impedance tomography since 2005.
I will post some pictures tomorrow of the circular base sustaining electrodes.
May be this can help you to understand some principles of the method, it mainly uses the ohm law.
en.m.wikipedia.org/wiki/Electrical_resistivity_measurement_of_concrete
https://en.m.wikipedia.org/wiki/Electrical_Impedance_and_Diffuse_Optical_Tomography_Reconstruction_Software
