Testing current on skin
08/30/2020 at 07:10 • 0 commentsTesting with low voltage AC using a 15 hz oscillator. -
I split the plywood board and wired electrodes to a data logger
08/30/2020 at 06:28 • 0 commentsI split the plywood board to make easier to accommodate a person chest (me) 👍 and wired electrodes to a data logger. I need to store voltage measurements using at least 12 electrodes as sense electrodes. Other part of electrodes should be used as current electrodes (input)
Updated to 36 electrodes
08/30/2020 at 05:46 • 0 commentsI added more electrodes considering the chest and electrodes size.
First 18 Stainless Steel electrodes and plywood board.
08/30/2020 at 05:44 • 0 commentsFirst step. 18 Stainless Steel electrodes and plywood board.
