a couple of images of the internals.
most of the "cheap Ebay boards" had to be modified, cut down, or split up to fit the constrains of the case. it fits together with the boards stacked and positioned closely to "almost" fully utilize the volume.
The screen contains the USB sound card, a small amplifier. and adapter board for the LCD under the one speaker and the LCD itself
