Simplest way to make a single-hand clock that synchronizes time via network, using a Raspberry Pi and a minimum of external components. This would have been much simpler to make with an Arduino and an RTC module. But I already had Raspberry Pi version 1s lying around without any use, so...
The envisioned end-use is to make a 24h mechanical clock that points out mealtimes and sleeping times. Because I have small children, and need to outsource the "No-no-not-yet-sleep-time" argument. At this latitude, sun sets around 23:00 at summer. So no use pointing out that it's already dark outside, when it doesn't actually get dark outside before 01:00 (AM).
1×
Stepper motor and driver
I used Velleman VMA401, which had both motor and driver. The motor is small enough to drive off the Raspberry Pi 5V pin. Manufacturer's page: https://www.velleman.eu/products/view/?id=435560
1×
Jumper wires with 2.54mm header connector
You'll have to splice and solder a few, so get good ones. E.g. https://www.adafruit.com/product/266
1×
150 ohm resistor
For limiting current to opto-fork's built-in LED. This value works with the listed opto-fork. You'll have to re-calculate value for other forks.
The wiring diagram is pretty self-explanatory. Connect motor driver and opto-fork power inputs to Raspberry Pi 5V. (This assumes that your motor uses less than 500mW of power, and can run on 5V, like the listed motor. Also assumes that your opto-fork is 5V.) Opto-fork's LED should have the 150 ohm resistor in line, to limit current.
Opto-fork's open-collector output needs the 10k ohm resistor pulling the signal toward 3.3V. But don't forget to connect the output to the GPIO pin too - making sure to connect the OTHER end of the resistor, so you don't short-circuit 3.3V to GND when the opto-fork output goes low.
I connected opto-fork output to pin 17, and motor control 1-4 to pins like IN1->GPIO27, 2->22, 3->23, 4->24. Note that the pin order in software needs to match the motor driver's input numbering, or the motor will not move right.
For building the software and configuring, see the file README.txt, in this project's files.
