1Making a Vibration Sensor:
- Take a single stand wire remove the coating.
- Make a spring using the wire.
Also take a straight wire of length same as the spring that we made.
Solder the spring and wire as shown in image to RST and GND of the Arduino board.
Make sure that wire is inside the spring and not touching the spring.
Using plastic tape cover the pins which are under the spring so that spring does not comes in contact to them.
2Circuit Connections:
- Make all the connections as shown in circuit diagram.
3Code:
- Code is given in the files section above.
- Open the code in Arduino IDE make sure to install FastLED library in the Arduino IDE.
- Connect the Arduino to PC,select the board type,select port and upload.
After the code is uploaded make sure everything is working.
4Final:
- 3D print the given STL files.
- Make a strap using the clips and belt or you can use any other strap that you have.
Assemble everything with the help of glue.
5Note:
- You can adjust the sensitivity of the band by adjusting the spring and the wire on the board.
- Adjust the sensitivity such that it should not trigger during the normal work, it should only trigger when the hand is jerked with a force.
Mukesh Sankhla
